Thanks for the info. I thought the trailer hook up would be too easy!They make winch kits that relocate the front center sensor. You cannot use the trailer wiring harness for powering the winch unless your trailer harness has zero gauge (battery cable size) wiring. Winches draw huge power.
I have never seen a setup like this. Pretty good idea to mount a windlass/ capstan driven thru a Pto, not limited by your drum capacity, just by how much rope you have on hand.Second the idea of the hitch mount if you can get a front hitch. I have all the parts but haven’t welded them up yet.
Also the PB gets one of the highest front GAWR but that’s still something to keep in mind.
One thing that needs to be be done by a good winch company is a high voltage motor instead of the common 12V which have a dizzying amperage draw.
One can dream that someday there will be a V8 hybrid with a front and rear PTO with a bunch of compatible accessories!
That looks awesome, was that a custom mount or is someone making that commercially? I did a quick google and couldn’t find a winch mount option like that one, pretty much exactly what I’ve been looking for.If you have a 5.0 you can add one behind the factory bumper.
^^^^^If you have a 5.0 you can add one behind the factory bumper.
I have a Jeep Rubicon - totally agree about the security of a winch. But I mounted my Warn Winch to a receiver plate since if I drive into something deep, what am I to do…climb in the mud pit and then drag my jeep to the other side -possibly going deeper into the mud pit? Wouldn’t I rather winch backward??? So I installed a front receiver. I keep the winch inside the back of the jeep so I can winch forward or back. I can winch a buddy from the front or the rear. Plus, in 4 years I have only needed it once. So it is in great condition, no one tempted to steal it, it is not weathered and I don’t have to replace the synthetic line due to weather wear. Lastly, I can use it with other vehicles. I ran a power feed to the front and rear of my jeep thinking I would need it more frequently, but a set of jumper cables with a plug on the end allows me to bring the winch anywhere with a vehicle that has a receiver. Definitely a smart move vs installing a winch - unless you want the cool look factor - which I miss out on.I'm thinking about adding a winch to the '24 Hybrid with the FX4 package. Any thoughts about how it might affect the over-all performance of the truck milage, braking etc? I've had them on Jeeps and they really give a sense of security off trail.
No, you cannot - the amp draw on a winch is huge! Buy a high quality set of jumper cables with heavy gauge wire and take the clamps off one end and install a quick disconnect - or wire direct to the winch with ring connectors. When you need to power winch, slide winch mount into receiver and then connect the jumper cables. Obviously the truck needs to be running when using the winch.Hitch mount. I never really considered that. I wonder if you can you power it by the trailering harness? I guess I'll check into that.
