I did swap ledI have no idea why you got rear tail lamp faults
okay well I just want my high beams to work and they don’tYou can’t run the calibration . It requires the sensors
might be cause I swap to leds tails and Blis modules are not programmedI have no idea why you got rear tail lamp faults
I stripped a platinum core support harness and I pin them to there locationHigh beams are not related to the calibration.
Im not sure what harness or forscan changes you made to the BCM.
anything in particular I need to check on the bcm with for scan
I won’t be much help with the halogen to LED P conversion. It’s similar but not the same as the upgrade I didOkay thanks tho I just ordered level sensors using your parts list hopefully that fixes my issue
I been told but I still want to do the full conversionThe auto level doesn’t prevent the headlamps from working with respect to high beams, turning beams, and even glare free
I have the connector part numbers, but the wiring harness is all part of the IP harness, that’s not something you’ll want to replace just for this. I’ll have to get it when I get home tonight thoughHi, do you have the part numbers for the wire harness parts on the powered column? I have the column just need to wire it up now. Thanks.
