LuisCarrillo91
So I left my 3.5 Ecoboost truck till it showed 9 miles to empty and I filled it and it took 30.246. I was wondering is the reserve about 5-6 gallons?
So does my truck have the wrong tank size then? Because I know the powerboost have 30.5 gallon tank size. Interesting. Does anyone had the same amount of gallons filled when truck is showing around 9 miles to empty.I was told by the service tech that there is no physical reserve tank, it is just programmed to give you a visual of 'Distance To Empty' and give you some safety to get to a gas station.
The way the Owner's Manual reads is that the increments at which you're alerted of low fuel is dependent on the way you drive. More aggressive driving warns you sooner since your forecasted fuel economy shows you'll be "dry" sooner than if you were being conservative with better MPGs.So I left my 3.5 Ecoboost truck till it showed 9 miles to empty and I filled it and it took 30.246. I was wondering is the reserve about 5-6 gallons?
Keep in mind MPG rating is lower under load/towing/4x4.Assuming 20MPG, a 5 gallon reserve will be 100 miles, that’s excessive and defeats the purpose of a fuel gauge because after you reach zero, if there’s still 100 miles of range, you will be going off the odometer, which is a little less accurate, since a headwind or “false flat” grade can hurt mileage over a longer period of time. Other than in a few spots, I have noticed that on the interstate, even in extremely rural areas, there’s a gas station every 5-15 miles and a 20 mile reserve is a handy safety for when you need to be reminded that you better stop at the next exit.
Yes, I always ignore the 50 mile DTE warning and then take the 25 mile warning as "time to get gas when convenient". It usually will only accept 33-34 gallons. I don't remember it EVER taking more than 35.is there anybody who has had the 36 gallon tank in an earlier generation truck?
WHAT?!?! There's an extra 5 gallons of useable fuel just sitting around under there? Yes, please someone who definitely is not me give this a try!I called Ford Tech service and they told me that it has a 5 gallon reserve tank. Hmm does anyone want to try?![]()
