275/65 r20 BFG KO2 pics?
flynavy
May 28, 2021
205
132
Midwest
2018 XLT
Pilot
They're right at 33 inches on the truck, though they're a 34 inch tire. I'm thinking they may be a little under inflated, actually, at 38ish psi cold. I might add a bit of air, to maybe 45 or so.
Is anyone else running their K02s at over 40?
I run mine at 42 but like the stiffer ride and better Fuel economy.
thebestbear
Ted
Oct 20, 2021
Boston
2021 F-150 STX
Contactor
Lost 2 mpg
Speedo is 3 mph off. Says I'm doing 70 it's actually 73
So you're speedo is off roughly 5%
So your odometer will also be off 5%
I think you're losing only about 1 mpg.
JerseyMike
Nov 2, 2021
56
50
Allentown, NJ
2021 F150 XLT 302A Carbonized Grey Sport 4x4
This is almost exactly what I plan to do only difference is I ordered the auto spring full kit with 3/4” rear lift in addition to 2” front
addition pics:
Papaw2018
Tony
Mar 29, 2022
206
138
Knoxville Tn.
Civil Engineer Tech
Leveled my lariat 502 fx4 this week. Rough country 2” billet spacers. 275/65/20 toyo open country at3’s. Still have exactly 1” rake which was what I was wanting. Ride is a bit stiffer as expected but still smooth. Mileage suffered a bit but hard to say how much as I only had a couple hundred on it prior. Speedometer is only off by 1 mph measured by gps.
So No rubbing on this set up? I like it and may do the same on my 2022 KR 4x4 FX4….if I ever get it🙄
JerseyMike
Nov 2, 2021
56
50
Allentown, NJ
I have the same, (2" spacer level and 275/65/20 with stock wheels). no rubbing and looks great
I did initially put a 3/4" lift in the back with it but pulled that out and it drives and rides great.
Papaw2018
Tony
Mar 29, 2022
206
138
Knoxville Tn.
Civil Engineer Tech
Thanks, @oddlou has the same setup as well. This looks like something I’ll most likely do once I get my KR. I just don’t want the tires to stick out past factory spec. I’m not fan of fatter tires rolling out past the fender edges (maybe a smidgen) but not real noticeable plus have all the rain splash and mud spraying up on the side. Thanks again
Polo08816
Aug 11, 2020
139
72
MD
2014 BMW 335i
That looks dope. Fills the wheel well perfectly. Crazy these trucks can fit 275/65/20’s stock.
I wonder if 275/65/20 will fit with a 20x9 +12 offset wheel (common Venomrex size and offset).
