'22 Google Maps in Cluster
Chrisski3
Christopher
Apr 18, 2022
2019 Explorer, 2022 F150
Software Engineer
Hey all,
I have a 2022 F150 302A that had the nav/SXM removal. I recently saw an F150 that had Google Maps turn-by-turn directions display in the instrument cluster when a turn was coming up. Is this something I could enable on my F150? Does this feature require the navigation module?
Thanks!
79
4,921
5,117
2022 307a PB, Mach E GTPE
It should already be showing up when a turn is imminent. Do you not get this behavior when navigating with google maps?
Jesse-Infotainment
Jesse
May 27, 2021
3,749
5,941
You probably could.
720-05-01
XXXX 01XX XXxx
You may have to
XX1X 01XX XXxx
Chrisski3
Christopher
Apr 18, 2022
Software Engineer
Not in the instrument cluster, no. The Google maps directions display properly on the screen, of course, but not the cluster
79
4,921
5,117
PM your vin
79
4,921
5,117
You're up to date on relevant software so follow the above thread for forscan changes. Here's the outstanding updates for your vehicle. For what it's worth you might look into adding the CCM which enables the autosteer of the truck
Ford F-150 '22 Google Maps in Cluster 1713630718989-60
You know if you add the CCM module (cruise radar), you'll get self steering as well as traffic start/stop auto following. A lot of those updates center around the latest bluecruise 1.4 control logic. It's about $450 in parts and 4 hours in time.
Chrisski3
Christopher
Apr 18, 2022
Software Engineer
Wow! I didn't know that's all it would take to add that. Would I need to replace the steering wheel to add the cruise buttons?
79
4,921
5,117
No, you just need the left buttons. Crazy to enable the self steering it just needs the unit, its bracket and a harness.
Chrisski3
Christopher
Apr 18, 2022
Software Engineer
Awesome, I'll do some research on that. Thanks for looking into all this!
Groovicles
Mar 14, 2022
133
116
2022 F150 XLT 302A PB Max Tow
Director
Hey all,
Thanks!
I have the same vehicle but with nav/sxm. When I use android auto my instrument cluster shows the next turn by default.
JIMFOUNTAIN
Jim
349
449
Austin, Tx
2021 F150 SCREW PB 6.5' 701A
Using Carplay... Apple maps ... I get turn info in the cluster. Google Maps or Waze... I don't get turn info in the cluster.
I was going to try the changes above ( 720-05-01 XXXX 01XX XXxx You may have to XX1X 01XX XXxx) but my 720-01-01 was already 0838 01E0 0856 so the xx1x bit was already set and the 01xxx was already there as well.
Getting ready for a 4K plus trip and would like to get Google maps turn info onto the IPC. How have others accomplished this? SW was FDRS'd to current 2/21/24 and everything else is working great.
Tnker
Feb 23, 2024
Pa
23 f-150
That is a normal thing with iOS devices. It’s a limitation of the CarPlay API and nothing to do with your truck. Apple has to fix it. That’s why it works with Apple Maps but nothing else
780
Todd
Feb 2, 2022
1,328
1,131
edmonton
Probably on purpose cause they want people using Apple Maps, not Google maps.
Apple Maps will display directions in the gauge cluster but when I use Google Maps it won't.
CarPlay thing I'm guessing. If I were to use Android auto, Google Maps would probably display directions in my cluster.
