21 F150 ReadyLift 2" Front Leveling Spacer Kit 66-2120
Stage3Motorsports
Diamond Sponsor
Apr 27, 2021
310
730
473
2021 F150 STX CrewCab 4x4
For those of you who are waiting for full coilover kits to be released, are saving money to go bigger, or who are just looking to level the truck out to get some bigger tires on there, these ReadyLift 2" Front Leveling Spacer Kits are perfect for you.
(in stock and ready to ship today)
Ford F-150 21 F150 ReadyLift 2" Front Leveling Spacer Kit 66-2120 1626970688519 Ford F-150 21 F150 ReadyLift 2" Front Leveling Spacer Kit 66-2120 1626970705355
Highlights:
  • Adds front ride height in a quality package
  • Reduces rake and adds clearance for big tires
  • Provides 2" of front leveling
  • Strong, corrosion-resistant billet aluminum spacers
  • Comes with new cam brackets and cam nuts
  • Backed by a limited lifetime warranty
  • Requires alignment after installation
Add 2" of Front Ride Height for Less Rake and More Tire Clearance
Getting the most out of your 2021 F150 means that you're going to have to jump up to bigger tires eventually, and a front leveling kit will let you do it. ReadyLift's 2" Front Leveling Spacers for 2021 F150s give your awesome F150 build just enough extra front height to even out your 2021 F150's stance while freeing up some room for bigger wheel and tire combinations. ReadyLift's 2021 F150 leveling spacers are made out of high-quality materials and come with everything you need to get them up and running on your awesome 2021 F150 build. ReadyLift's spacers add 2" of total front ride height to your truck which helps eliminate front rake for a more even front-to-rear stance and gives you some extra clearance to mount larger and more aggressive tires to handle your next adventure. Durable Billet Aluminum Construction with New Cam Plates and Nuts
ReadyLift's 2" leveling kit for 2021 F150s features a high-quality construction and comes with all the hardware you need the kit installed and truck properly aligned. The spacers themselves are made out of 6061-T6 billet aluminum that makes the spacers incredibly durable and resistant to corrosion in any climate, environment, or application. The billet leveling spacers install right on top of your F150's factory coilover assemblies without the need for stud trimming or other permanent modifications. The kit also comes with new cam nut and alignment plates for your F150's lower control arms that allow for much easier alignment after your leveling spacer install. Each kit comes with installation instructions and hardware. ReadyLift backs this kit with a Limited Lifetime Warranty.
Fitment: 2021 F150 4WD & RWD
Requires Alignment: since this kit comes with new cam nuts and cam plates, your truck will require an alignment after installation.
Will not fit CCD Suspension Systems: ReadyLift's spacers are not compatible on F150 models equipped with Ford's Continuously Controlled Damping (CCD) suspension. Please ensure your truck is equipped with a standard suspension before ordering.
dannko58
Dan
Jul 26, 2021
113
New Braunfels TX
2021 F150 Lariat, Powerboost, Supercrew, FX4, 502A
Professional Bum
Highlights:
how do we know if our ordered truck has the CCD suspension?
Stage3Motorsports
Stage3Motorsports
Diamond Sponsor
Apr 27, 2021
310
730
473
If you dont have the truck yet best bet would be to ask the dealer. Being the truck is still pretty new im not sure exactly what options/packages ccd Is included with.
Hercules
Zack
Jul 7, 2021
Ontario,Canada
2021 Ford F-150 Lariat FX4 Sport package
heavy equipment Parts Specialist
Highlights:
is readylift or someone working on a leveling kit compatible with ccd ?
Stage3Motorsports
Stage3Motorsports
Diamond Sponsor
Apr 27, 2021
310
730
473
Sorry for delay must have missed this comment. Im not aware of any at the moment, but being how new the truck is its just a matter of time.
SumGuy
Jul 21, 2021
483
382
F150 (perpetually on order)
Drugs
Any discount codes for forum members?
