120
8,124
9,288
2022 307a PB, Mach E GTPE
Reducing road noise by nearly 5db is pretty damn good. A reduction of 3db is perceived by the average ear as 'half' as quiet.
honda250xtitan
Aug 10, 2024
103
85
Phoenix
2023 F150 XL Rattler
this is crazy context.
nice job to the OP.
120
8,124
9,288
In the crew cab there was already NVH coating on most of it and the super thick carpet works well. Not sure how the reg cab is. I instead focused on the plastic pieces
v8440
Aug 21, 2024
636
669
Iowa
'24 f150 xl rcsb
Urinal cake replacer
Actually, that's not quite correct. A 3dB reduction reduces power by half, meaning the intensity of the sound reaching the ear (or radio waves reaching an antenna) is reduced by half. However, a 3dB reduction does not sound half as quiet, the apparent reduction is less than that. It takes a 10 dB reduction to reduced perceived volume by half. Or put differently, it takes a 10 dB increase to double perceived volume.
So, if you double the power supplied to a speaker a 3dB increase in loudness will be heard. If you supply 10x the power to the speaker, a 10 dB increase in loudness will be heard, which is perceived as roughly a doubling of volume. If you supply 100x the power to the speaker, a 20 dB increase will be heard, which is a quadrupling of apparent volume to the ear.
120
8,124
9,288
There's also another variable at play here that isn't registered on a decibel meter that some people overlook. By adding dampening material, it's both reducing the noise level while simultaneously changing the frequency essentially turning 'white' noise to 'pink'. Less higher harsh frequencies turning 'shhhh' to 'cuhhhhhhh'.
This can be observed in some of the noise tests TFL does using a decibel meter alone. It's funny watching the guess what the noise level is but they can't quite nail it in some vehicles because it has harsher (higher) frequencies but they just accept it because the meter doesn't lie after all.
v8440
Aug 21, 2024
636
669
Iowa
'24 f150 xl rcsb
Makes sense, the meter has flat response but the human ear doesn't, and then you add to that the mind's reaction to noise which tends to find higher frequencies more disturbing than lower. I just wanted to point out some stuff that strictly speaking isn't quite the way you said it when it comes to decibels vs power and volume.
ProperRCLB
ProperRCLB
Roger
Jan 28, 2025
112
124
New England
2024 RCLB F-150 5.0 XL 4x4
Here is an Update.
Added Resonix CDL + Resonix Guardian to the Door Panels. Unfortunately do not have too many pictures. Also ordered Block off Plates for the front door by SoundsGoodStereo and Second Skin Damplifier Pro Butyl for the inner side of the doors. Note: I have not installed any sound proofing barriers yet (like MLV).
Ford F-150 2024 RCLB (Long Bed) 5.0L Carbonized Gray OEM+ Lariat Build IMG_1575.JPG
Lot of vapor/humidity inside the doors:
Ford F-150 2024 RCLB (Long Bed) 5.0L Carbonized Gray OEM+ Lariat Build IMG_1556.JPG
OEM Barrier Removed:
Ford F-150 2024 RCLB (Long Bed) 5.0L Carbonized Gray OEM+ Lariat Build IMG_1558.JPG
Resonix CDL + Resonix Guardian installed on outer door panel.
Ford F-150 2024 RCLB (Long Bed) 5.0L Carbonized Gray OEM+ Lariat Build IMG_1562 2.JPG
Results:
Fully stock: 75.5 db @ 35mph
Resonix on Rear Wall: 71.1 db @ 35mph
Resonix CDL+ Resonix Fiber Mat on Rear Wall + Resonix CDL on Headliner/Roof: 70.6 db @ 35mph
Resonix CDL+ Resonix Guardian Door Panels: 69.6 db @ 35mph
Total Reduction:
5.9 db
Next:
  • Block Off Plates on Interior side Doors
  • Second Skin Damplifier Pro Butyl (a bit more manageable than Resonix CDL) on Interior side Doors
  • Resonix FiberMat 25 on Interior side Doors / Door panel
  • OEM Carpeted Floor Liner and remove OEM Vinyl
  • Resonix Barrier (MLV) on Floor Liner
ProperRCLB
ProperRCLB
Roger
Jan 28, 2025
112
124
New England
While there, began updating the interior to the 2024 Lariat interior. Door panels are in! Steering wheel, Black carpet and leather seats coming next.
OEM XL:
Ford F-150 2024 RCLB (Long Bed) 5.0L Carbonized Gray OEM+ Lariat Build IMG_1577.JPG
OEM Lariat:
Ford F-150 2024 RCLB (Long Bed) 5.0L Carbonized Gray OEM+ Lariat Build IMG_1582.JPG
The new door panels is an exact match to the 2024 XL Dash so I do not have to upgrade that to match (thankfully!)
Ford F-150 2024 RCLB (Long Bed) 5.0L Carbonized Gray OEM+ Lariat Build IMG_9D866151701B-1
120
8,124
9,288
Nice work -- have you gotten to the roof yet? Makes a big difference in the rain for sure
120
8,124
9,288
One thing I noticed is I do not have this sound deadning mat on my OEM door panels and they did not come in the new door panels I Installed.
Oh wow so XL doesn't have what I refer to as the "pillows"? My XLT has them.
I added ambients in the door panels and went full retard on dynamat (back of the top looking down at the pocket, lights bleed through the slit above the pocket)
Ford F-150 2024 RCLB (Long Bed) 5.0L Carbonized Gray OEM+ Lariat Build 1739057429851-is
Door handle area
Ford F-150 2024 RCLB (Long Bed) 5.0L Carbonized Gray OEM+ Lariat Build 1739057494660-iw
Lines indicate where I put LEDs, tied them into the door lock illumination circuit which is on the dimmer
Ford F-150 2024 RCLB (Long Bed) 5.0L Carbonized Gray OEM+ Lariat Build 1739057602684-py
Everything got butyl rubber -- I mean everything. Didn't photo what I did to the console, everything torn apart and butyl rubber and fabric tape on every single joint / clip / interface rub location.
Ford F-150 2024 RCLB (Long Bed) 5.0L Carbonized Gray OEM+ Lariat Build 1739057917721-9x
ProperRCLB
ProperRCLB
Roger
Jan 28, 2025
112
124
New England
Door handle area
Nice! Did you measure it? I'm curious what yours would read using DecibelX app: https://apps.apple.com/us/app/decibel-x-db-sound-level-meter/id448155923
120
8,124
9,288
No. It was pretty quiet to begin with. It's real quiet now. I went around beating on everything with my fist to find noise. Then I just went overboard. Every single piece of plastic in the truck is treated. Everywhere it interfaces to is treated. Everywhere 2 plastic parts touch there's a combo of butyl rubber and fabric tape.
