2022 Power Boost Intercooler Upgrade
Aug 14, 2022
33
Rockledge
2022 F150 Power Boost
2022 Now in production and have been doing research on minimalistic power upgrades the last few months. The intercooler swap seems like a no-brainier but there is not a ton of feedback on this. Looking for feedback/experience and preferred Intercooler MFG's i.e. CVF, Whipple, Titan or others. Which has the best plug and play abilities and better power increases. Also blow off valve and any other integral turbo upgrades while doing this one. TIA!
DanielG
Daniel
Jun 15, 2021
134
85
33834
2021 Ford F150 Lariat
What would changing the inter cooler do for me ?
notabot
Sep 18, 2021
432
379
Americas
Yes
Is your truck tuned? FWIW, I did an intercooler upgrade on a Golf TDI and w/o tuning and other changes, performance bump is minimal.
Aug 14, 2022
33
Rockledge
I have not received the truck yet should ship in another week. From what I have read the 2022 PB comes from the factory like a tuned truck from a few years ago. If you do some searching on YouTube there are a few videos that they had on a Dyno to prove performance of the upgraded intercooler. Numbers were anywhere from 40-60HP gains on the performance. Well worth the money if accurate in my opinion.
Mosey
Jun 26, 2022
64
404
262
2021 F-150 Powerboost
If accurate that is an amazing bump.
imnuts
Mar 1, 2021
1,513
1,591
Dirty Jerz
'21 502A Powerboost 4×4
Facilities Engineer
How much it helps you is going to be dependant on where you live and how you drive. Don't live in the Southern US, actual gains are going to be lower for DD trips, and unlikely to change anything. Same thing if you're rarely getting into boost as you wouldn't be heat soaking the intercooler.
Dresdie
Apr 23, 2021
366
248
Ohio
2009 Acura TSX
Without a tune to go with it, I dont think you'll get much performance improvement (if at all) over stock. However, an upgraded intercooler will certainly give you *more consistent* performance when putting a consistent workload on the motor (ex. towing).
An upgraded intercooler is primarily going to keep the turbo heat from *negatively* impacting your existing performance when temps are up.
That all said, I also plan to upgrade the intercooler on my PB for future towing reasons. Eager to see some feedback from those who've upgraded their PBs.
Dresdie
Apr 23, 2021
366
248
Ohio
2009 Acura TSX
Livernois has video of a PB with upgraded intercooler on YouTube but, they also had a tune. Sure it wasn't the Livernois video? They showed some solid 40-60hp gains on dyno with their tune.
9,229
16,892
3.5 Ecoboost has now been around for more than a decade. Lots of real world data shared with knowledgeable owners.
The oem cac is built to a cost point, so yea, the aftermarket upgrade is a worthy option.
Having said that, as mentioned a couple of times previously, an untuned Ecoboost would not likely experience an appreciable increase in power, but it would very likely benefit from not LOSING power from being heatsoaked as easily and having timing being pulled as a result.
05RubiconLJ
Matt
Aug 6, 2020
40
881
755
Arkansas
I would be curious to see how much more flow/cooling the upgraded intercooler produces with the active louver system in place. Unless you are really in the gas (spooling), those intercooler louvers are going to stay closed. It is my understanding that mpg loss is noticeable without the louvers.
Between normal cruising, engine and electric, the majority of owners are probably not going to see any marked difference. I do agree with upgrading the intercooler, and replacing the plastic blow-off valve, if you are going to be regularly towing or romping on it.
9,229
16,892
I removed the louvers a few tanks ago and did not notice any change in fuel mileage at all. Or at least the difference was well within the variance of one day's commute and the next.
But on a Powerboost I also didn't notice a substantial change in IAT2 temps. But it seems that is more a result of the repeated EV events which leave the Intercooler inoperative while at the same time the heated engine block cooking the stale air captured in the intake plenum.
The louver removal does cool the IAT2's a bit quicker, once the ICE is re-engaged. So there's that. But the overall drop in temp was only about 5F from what I witnessed.
Still, I'm not putting the louvers back in.
bowling
J
Jan 27, 2022
51
Berlin
F-150
why bother? 430 horsepower and 569 lbf.ft torque is more than enough.
Aug 14, 2022
33
Rockledge
Why not is more the question.
If you can add 20-50HP with little investment and or effort why wouldn't you? Just seems like low hanging fruit not to mention the benefit of the upgraded components.
