TylerNinetyTwo
@TexasTruck I have on order a 2022 Regular Cab, 101A, 5.0L V8, Fog Lights, Trailer Brake Controller, 3.31 Axle, and Hitch. Do you think this mod would be as easy on mine as it was with yours? I see that you have the Trailer/Tow Package which I do not. I've seen mentioned earlier in the thread that some trucks won't have the wires populated at the BCM to make this a quick and easy job. Seeing as how you have a somewhat closer version of my truck than the other members I was hoping you might know. Thanks! If anyone else could chime in that would be great. I really want to install these lights as I have to load gear into my truck at night quite frequently.I have the factory wiring with the dummy ends in each corner (XL/STX 101a). I ordered the parts as you said. Removing the factory blank covers was interesting. Routed and attached the two pigtails like the factory without removing the tail lights. Set the 4 FORSCAN settings in the BCM, and let there be light! Works perfectly! Thank you Gene!
