MDmann
Matthew
Jacksonville, Fl
2022 F150 SXT 4x4 supercrew 2.7EB
Superintendent
Got the quick before and after pics attached. Ended up with 2.5 inches of lift. The puck was only 1.75 inches thick, so I’m lost as to what happened.
I didn’t tighten the suspension till it was resting on the wheels. (Upper A arm bolts where a pain to get torqued down with the wheels on. Lower a arm bolts were no where near 257 ft lbs from the factory.)
It rides as nice as before, dropped it off the alignment around lunch, they had it done in about an hour. I was hoping it would relax some and get closer to 2”.
Has anyone had a similar issue? I really didn’t want to be over 2”.
Ford F-150 2022 F150 Screw STX 4x4 on 2" Rough Country Lift Kit C981B668-C609-45B4-A24C-62C5B972E592
Ford F-150 2022 F150 Screw STX 4x4 on 2" Rough Country Lift Kit D54BB9B3-A21E-40F7-8AE4-37535E6F516D
  • Like
Reactions: 780
MDmann
Matthew
Jacksonville, Fl
Superintendent
My driveway in the last pic is not a level surface. So it looks more than 2.5-3”. I’ll update tomorrow if it relaxes at all.
MDmann
Matthew
Jacksonville, Fl
Superintendent
It was a rough night before, real thick puke. I drove about 50 miles and I’ll check it when I get home, this evening.
Im still in shocked, it didn’t change ride quality.
GIjoe
Joe
May 20, 2022
327
224
Ohio
2013 f250
It’ll probably be easier to just add a bigger block in the rear if you think the front looks too high. Go a size up in tires and it would look really good
Graygoose2021
Nov 18, 2021
31
1,892
1,801
Central US!
Sales
Mine looks off too, but I've heard, put a level on the rear pinch weld under doors, see how level you are. Don't measure ground up to bottom of the wheel well, as the rears are much larger than the fronts, from the factory.
Rockman5159
Rocky
Nov 19, 2021
672
396
Marion SC
2021 ford f150 FX4
My Rough Country Struts 2" raised my front end 2.75 inches. It took it almost a month but then settled to just a touch over 2"
MDmann
Matthew
Jacksonville, Fl
Superintendent
It is settling down. It’s a little over 2” now. Attached are 3 photos. Washed and added black out lettering for the tailgate.
Ford F-150 2022 F150 Screw STX 4x4 on 2" Rough Country Lift Kit D2B4C0E2-402A-4EBA-B8B8-CFA0A3B0D4DC
Ford F-150 2022 F150 Screw STX 4x4 on 2" Rough Country Lift Kit 44543926-0DE9-4454-9041-DD7B8C168391
Ford F-150 2022 F150 Screw STX 4x4 on 2" Rough Country Lift Kit 5D77490D-895B-4D28-8968-BFF007A113C0
Graygoose2021
Nov 18, 2021
31
1,892
1,801
Central US!
Sales
@MDmann
Looks good, maybe add the Ford OEM smoked emblems , would look great against that darker truck
Ford F-150 2022 F150 Screw STX 4x4 on 2" Rough Country Lift Kit 20220604_124356_resized
Ford F-150 2022 F150 Screw STX 4x4 on 2" Rough Country Lift Kit 20220701_153803
hotrodmex
Feb 4, 2022
972
855
Ca
22 Lariat 500.5a
As far as I've seen, RC has just ported their Gen 13 parts to the Gen14. The Gen 14 has a different motion ratio, though, so the lift will end up higher on a Gen 14 for the same spacing.
The spacer is multiplied by the ratio of shock movement to wheel movement. I think Gen 14 is about .7:1, where Gen 13 was .6:1 or so. I haven't looked it up yet, but someone said the track was widened a bit on the Gen14, and if they did that from the inside that would move the ratio that way.
MDmann
Matthew
Jacksonville, Fl
Superintendent
Holy cow. It’s relaxed to a little over 2” now. I didn’t know that about the ratios of shock travel. That gives me something to read about while the hurricane is hitting my state.
Rockman5159
Rocky
Nov 19, 2021
672
396
Marion SC
2021 ford f150 FX4
Stay safe and good luck down there
MDmann
Matthew
Jacksonville, Fl
Superintendent
Thank you, We are in Jax, so we will get our tomorrow/Friday. As a native Floridian, we stay pretty prepared, but also don’t get too stressed. Generator and vehicles are gassed up.
Mscott2
Michael
Sep 14, 2022
Baton Rouge, La
22 SuperCrew 5.0
A 2” Readylift kit is the best to use, and after you will still have a slight unnoticeable rake. Which is a good thing!
