MJG44
Are you able to get a couple other shots of those mirror cap overlays? There's gloss black ones but not so certain about how they look when not looking straight on.
Is your exhaust stock ? I am going to do the exact same thing as you in my supercrew rear wall and floors, I changed my stock muffler and getting a drone at certain rpm’sSound deadening project is done on the floor and back wall! Doors will have to wait for another day.
80 mil butyl covered by 315 mil closed cell foam. The two layers make a huge difference. I can hear the air conditioner and the radio over the exhaust now! At idle in normal mode, you can barely hear the engine running.
Unfortunately, the only picture I took was when it was stripped down. Glad I did it when the truck was still new. Very little cleanup required. A quick wipe down with alcohol and it was ready to go.
I have the Magnaflow Street Series side exit. The noise level is definitely higher than a rear exit but it’s not unbearable and I don’t have drone.Is your exhaust stock ? I am going to do the exact same thing as you in my supercrew rear wall and floors, I changed my stock muffler and getting a drone at certain rpm’s
Okay thanks, did a search through your posts and saw it. I just have a fairly quiet Borla pro xs muffler installed, everything else is stock. If the sound deadening material and closed cell foam made a big difference for you then it should solve my noise issueI have the Magnaflow Street Series side exit. The noise level is definitely higher than a rear exit but it’s not unbearable and I don’t have drone.
I still want to add sound deadening to the doors. I imagine that will have some additional benefit.Okay thanks, did a search through your posts and saw it. I just have a fairly quiet Borla pro xs muffler installed, everything else is stock. If the sound deadening material and closed cell foam made a big difference for you then it should solve my noise issue
Think i will do the back wall, floor, and rear doors for now. Forgot to ask, with both the 80mil butyl and 315 mil foam did the rear wall carpet liner fit back in okay ?I still want to add sound deadening to the doors. I imagine that will have some additional benefit.
The back wall was not an issue at all. The single cabs have a single piece of molded, felt-like material. Not sure if that’s the same as the other cab configurations or not. I just made sure not to cover the two vents in the back wall.Think i will do the back wall, floor, and rear doors for now. Forgot to ask, with both the 80mil butyl and 315 mil foam did the rear wall carpet liner fit back in okay ?
