Recently added to our site is the Auto Spring 2" Rear block kit, with u-bolts for the 21 F150
2021 F150 4WD & RWD Auto Spring 2" Rear Blocks
Auto Spring 2021 F150 Rear Block Features:
Whether you need to get some extra rear ride height for preventing squat when towing heavy or to help you win back a bit of rake after installing a front leveling kit, adding a slightly larger rear block to your 2021 F150 may be a good bet. The Auto Spring 2" Rear Block Kit for 2021 F150s add around .75" of rear ride height to 4WD F150s. The increase in ride height on the 4WD F150s is just enough to help keep your truck level when you're towing and hauling heavy or to give you back a bit of rake after adding a leveling kit so you don't end up sitting nose-high when towing or hauling. The Auto Spring 2021 F150 2" Rear Block Kit features a durable construction and drops right into place of your F150's factory block without modifications, making them an easy, hassle-free upgrade for your awesome F150 build. Fabricated Steel Lift Blocks with Black Polyurethane Finish and Grade 8 U-Bolts
The Auto Spring Rear Blocks are made to be incredibly strong all while easily dropping onto your truck. Each of the blocks included in this kit are made out of fabricated 1/4" steel that are expertly welded together for a perfect fit onto your F150. The blocks come standard with a black polyurethane finish that protects the blocks from corrosion while letting them blend in with your F150's undercarriage. The block kit comes standard with grade 8 U-bolts and nuts that keep the blocks locked to your F150's axle no matter how hard you're ripping your 2021 F150 around. The Auto Spring rear blocks are easy, drop-in replacements for your F150's stock rear blocks. These blocks are made right here in the USA and come backed by a limited lifetime warranty.
Fitment: 2021 F150 4WD & RWD
Ride Height Note: this rear block adds .75" of ride height on 4WD F150s as a replacement for the stock block. On an RWD F150 without a rear block, Auto Spring's blocks will add 2" of ride height.
- Adds ride height for increasing rake or helping with towing
- Pair of 2" tall rear blocks with U-bolts and nuts
- 1/4" thick, fabricated steel construction
- Black polyurethane finish
- Comes with grade 8 U-bolts and nuts
- Backed by a limited lifetime warranty
- Made in the USA
