Zyvin
732
959
SC
2021 F150 Crew, FX4, Lariat
I did have trailer hooked up And truck in my driveway. I have not tried 726-02-01 I will try that next thank you.
Yea, the thread below has some info in it. Seems some has to get a software update to stop the false alarms.
Platinum Peasant
Sep 26, 2020
79
904
947
West Sacramento
2021 Ford F150 Platinum 3.0 Powerstroke
Neonatal Respiratory Therapist
On the 2018 F-150, I was able to change the DRL's to be on AND for the rear C-clamp lights be on at the same time, with the headlight beams off. Can this be done on the 21?
DRL - Parking Lights only (stock LEDs only)BCM726-26-02x1xxxxxxxxxx
726-50-0101xx
HCFX
Oct 15, 2020
163
206
2023 F-150 Lariat BAP
Does anyone know of a way to write reverse brake assist completely out of the truck? Mine jams on the brakes for no reason every single time I back into my driveway and when I shut it off it chimes at me every time I shift to reverse to let me know it's off. It's making me real annoyed with the truck.
Missmy3/4ton
May 13, 2021
248
129
Midwest
300a XLT 5.0 4x4
I worked with someone on enabling the wired keypad to his truck and confirmed the following works so it's been added to the common spreadsheet:
BCM 726-31-01 xxxx xx01 xx--
APIM 7D0-01-02 xxxx x*xx xx-- (optional) - adds door keypad code screen to Sync settings use 6 if you have ambient lighting or 2 if you don't
If you don't know your truck's factory code then you can get it to display if you have both vehicle keys with the following procedure:
1. Insert first key in ignition and turn to ON wait 4 seconds, turn OFF and remove key.
2. Insert second key and turn to ON wait 4 seconds - FACTORY KEY CODE will display on instrument panel. You can now use factory code to change code in SYNC.
Thanks! I just picked up my wired key pad so I will be installing it this week/end. I will be making both the line changes for the keypad and sync
726-31-01 xxxx xx** xx-- KeyPad_Enable_Cfg: 00=Disable 01=HW_Input 02=LIN_Input
MichaelG_252
Michael
Jun 11, 2021
27834
2021 Ford F150 STX
@Missmy3/4ton Let me know how your keypad install goes. I just did this on my '21 STX... with some help from @Livnitup.
Livnitup
Livnitup
Jul 15, 2020
249
627
SoCal
2021 F150 Platinum
I installed a HDC (hill descent control) button into my non-FX4 4WD and have been chasing the values to get it fully functional but I did discover a few things this morning that are of interest...
ABS 760-04-01 xxxx xx8x xx-- adds Rock Crawl to Drive Modes
Ford F-150 2021+ F-150 FORScan List / Database / Spreadsheet rock crawl
ABS 760-04-01 xxxx xxx8 xx-- Adds Trail to Drive Modes
Ford F-150 2021+ F-150 FORScan List / Database / Spreadsheet Trail
Note: I briefly played around with the SDM_Generic_Modexx entries on the ABS spreadsheet to try and produce different modes using "F" as a quick way to enable multiple ones at same time but didn't see any additional drive modes appear on the cluster. Also, I didn't test Rock Crawl or Trail modes while driving so if anyone is inclined then do so at your own risk. I realize Rock Crawl is standard on FX4 trucks but I haven't tested that yet until I get my HDC button functional.
Livnitup
Livnitup
Jul 15, 2020
249
627
SoCal
2021 F150 Platinum
Icewraithusa
Craig
Jun 3, 2021
Denver, CO
2021 F-150 XL 3.5 EcoBoost
Do we have a write-up anywhere on how to retrofit that door keypad? Mine also didn’t come with one (XL w/STX) and I’d love to add it.
MikeYQM
Jul 3, 2021
146
96
Moncton NB Canada
2021 F-150 Platinum Powerboost | 2013 BMW M3 Comp
Hi everyone, this is my first post regarding my first F-150… and thus my first experience with ForScan. I apologize if my question(s) are simplistic. Huge thanks for the resources listed in this thread, no small amount of work!
1. If I enable Wigwag in the HCM, will this cause the 4-way flashers to wig wag or is hardware required?
2. same question about the rear fog in the TRM, any hardware required? Turn on with front fogs?
Sentinel1201
Jun 5, 2021
197
225
DFW
2021 F150 Powerboost
Hello @Livnitup, my 21 PB has Max Tow and is a Lariat with the power mirrors. I have the lane centering system, BLIS and radar cruise as well.
The only thing I don't have is the 360 camera package. Since I have the max tow and lane centering and power mirrors with BLIS, do I already have the required cameras for the 360 camera? Am I able to just enable it with forscan?? Or does the 360 camera package need any unique hardware that I don't have??
Livnitup
Livnitup
Jul 15, 2020
249
627
SoCal
2021 F150 Platinum
No, you wouldn't already have the required cameras if you didn't order the 360 package. For example, your side view mirrors don't have cameras on the underside of them that make up part of the 360 degree view.
YOCUBED
Oct 28, 2020
56
64
Tuscaloosa, AL
2020 GLE 450, 2016 BMW M3, 2021 F150 Limited
Emergency Physician
@Livnitup do you know if there is a way to get the rear c clamp lighting to be on with the DRLs like in prior years? Still waiting for my obd ex cable to arrive so I can delve into the settings but hoping to see if someone had already figured it out.
Thanks
