dolsen
Aug 19, 2022
2,085
1,901
KY
2022 Rapid Red 701A
Disable status bar temp (SBT) in 7D0-02-02 *xxx xxxx xx—
Hmm, I have a 4 in that spot and a "4" in that spot disables all items associated with that bit... not sure what that means
ROBB1
Justin
Oct 10, 2021
289
364
NC
2021 F150 Tremor
Sorry I forgot this particular one is counter intuitive: set SBT to ”ON” to eliminate the temps at the top of the screen.
Cheez_Greater
Jason
Jun 1, 2022
85
73
Washington
2021 F-150 Lariat
BI Developer
Perfect, I needed this, I thought I did this last night but I removed the temp from popping up on the middle of the screen when changing
What line(s) did you change to remove the temp pop up? I hate that feature.
dolsen
Aug 19, 2022
2,085
1,901
KY
2022 Rapid Red 701A
This was the change that I made:
Ford F-150 2021+ F-150 FORScan List / Database / Spreadsheet ? 1682260833643
Just verify your stock value and then use that to change the "TR On" to "TR Off". Your value may or may not be the same as mine
Ford F-150 2021+ F-150 FORScan List / Database / Spreadsheet ? 1682260866412
dolsen
Aug 19, 2022
2,085
1,901
KY
2022 Rapid Red 701A
Looks like I'll be changing mine from a 4 to a 0
Ford F-150 2021+ F-150 FORScan List / Database / Spreadsheet ? 1682260997843
vidwiz
Derek
Jan 22, 2022
147
74
2022 Platinum Powerboost
Going to the dealer tomorrow for A/C shutting down, auto level headlights not working, and calibration of scales/ride height sensor. With all the forscan changes I've done, seems anyone that knows these trucks is going to notice that the pedestrian sounds are off, there is a glare free option in the settings, the seat belt nag is gone, there are digital readouts for temperature, there are driving modes not associated with a Platinum, additional auto seat heat/cool settings exist, and the opening animation is different. I've read some other opinions not to worry about it but any new input on whether I should be returning these mods to stock? Seems I would need to do them manually so as not to risk any changes that might have come thru with the several updates I have received since I did the original backup, then being lost in the restoration. Hopefully that makes sense. A pain to pull everything back up, study it, and enter, then re-enter after service. And always a risk of entering a wrong value too, so trying to avoid any messes. Have it nicely personalized now. But certainly would not be worth it if for example the dealer blacklisted me as a modder and voiding both existing and extended warranties. Perhaps the inconvenience is the price a tinkerer pays?...
dolsen
Aug 19, 2022
2,085
1,901
KY
2022 Rapid Red 701A
It would seem to me that your FORScan changes may have impacted your ride height sensors and auto level (which are tied together to some extent, or maybe fully tied together depending on your packaging)
GDN
Greg
Feb 15, 2022
337
311
Dallas, TX
Lightning -Lariat ER, Model 3
IT
On these newer trucks, all of these changes get uploaded to the mothership eventually and then become your "As Built" data. If you remove these just a day or two before you're in for service - the truck and the As Built likely won't match as sometimes it is slow to update the mothership.
bigbulls
Mar 25, 2023
59
41
Or
2023 F150 Tremor
I've done several forscan changes, but is there some where I can get rid of the dinging when I start the truck? I don't mind the screen 75th stuff going on but the dinging drives me crazy. I'm guessing I missed it somewhere because I can't imagine somebody hasn't figured this one out. Thanks
personalt
Rich
Oct 8, 2021
33
359
151
NJ
Tacoma / Cayenne
Note: The last column was my AsBuilt setting before changing. I check Livnitup spreadsheet to make sure I had the correct changes for my truck for each one. RED lettering was AsBuilt, yellow highlighted was changes used for my 21 Platinum. My truck has all the required options for this. Hope this helps.
APIM7D0-01-03xxxxxxFxxxxx724D-25E5-3FE3
ABS760-03-01xxxxxxBxxxFBA0-06
IPMA706-01-01xxxxxx5xxxxx8A50-A215-AE4E
Do you know what hardware you need from this? I got a IPMA out of a platnuim with all the bells and whistles and added it to my XLT. Do I need a special trailer module or is the higher level IPMA enough? My main goal when buyign the IPMA was 360 cameras and parking assist (I did add 6 parking senors in front and have two ready to go in to back bumper next week.
personalt
Rich
Oct 8, 2021
33
359
151
NJ
Tacoma / Cayenne
Anyone have any info on what settings to chanage to enable parking sensors and add full park assist? So far I added 6 front sensors to my 302A XLT and I have two more for the back which should get me park assist compatilbe (I have a IPMA out of a 2021 platnium that had those features).
Cobraman428
Jerry
Dec 21, 2021
359
688
Tampa Bay Florida
2021 F150 Platinum PB 701A MT FX4
VP of IT
Sorry, I do not know what hardware is required for this option to work. I have a 702a package on my truck with almost every option, I figured I would turn this feature on to see if it worked. The main reason I got this truck was for towing a travel trailer. I'm getting my trailer later today and I'm going to test it to make it 100% works.
Paul Neubauer
Paul
Nov 20, 2021
568
516
Houston
2021 F-150
I am curious what they end up fixing for your headlights. Mine are never leveling correctly when I remote start the truck and require a restart to fix every day now.
Paul Neubauer
Paul
Nov 20, 2021
568
516
Houston
2021 F-150
Does anyone know where the Forscan option is to do a manual regen on the diesel engine? It was under the service procedures along with a bunch of other diesel specific tools but is gone now in the past few updates.
