Vulnox
- Bob
- Mar 19, 2021
- 4
- 341
- 443
- Livonia, MI
- 2021 F-150 Lariat 502A, 3.5L PowerBoost
Too old to be super relevant I guess, was the first gen of 3.5L EB. I don't know that anyone will be able to tell you much on comparing them though. The 3.5L and 2.7L and even the 5.0L will drive very similar to each other, they are just gas engines in the end. The EBs have turbos, so if you get into it, you will feel the truck launch harder at lower RPM than the car engine in the V8 F-150.All great points. So last question what year was your 3.5 and how did it compare to the powerboost?
The powerboost is just the one I can’t drive since it’s not in my area so I’m trying to gaugehow it compares
The PB is a different beast because it has a motor with instant, 0RPM torque that helps get you off the line, even when the gas engine is running. So from a launch, the truck is instantly responsive. No turbo lag build or anything because by the time you have hit the limits of what the electric motor can immediately assist with, boost is built.
The biggest driving feel advantage to the PB is when it fills in the gaps. As I mentioned in my earlier post, a normal EB truck uses boost to fill in power gaps without having to change gears. Boost requires time to build and consumes more fuel. The PB uses the electric motor to fill those gaps, within reason, only engaging boost for significant demand. This results in a smoother overall feel for everything you do. It's probably the smoothest and quietest powertrain I have ever driven aside from my wife's FFE.
But, none of that will be missed if you don't drive it. Like comparing an OLED TV to a high quality backlit LED TV, if you place them side by side, the benefits of the OLED are immediately apparent, but it costs more money. If you don't look at the OLED and just look at the backlit TV, it will likely still be as much, or more, than you need, still look fantastic, and will cost you a lot less.
