Now available and ready to ship!
2021-2022 F150 S3M 2.3" Offset Spacer Leveling Kit S3M-21LK1
F150 Stage 3 2.3" Leveling Kit Features:
The 2021-2022 F150s sit a bit different than the trucks that came before, and a lot of leveling kits on the market just don't quite give them the stance they need for a clean look and tire clearance while avoiding spring contact with the UCAs. The Stage 3 Motorsports 2.3" Offset Spacer Leveling Kit for 2021-2022 F150s provides the perfect amount front lift for your 2021-2022 F150 build while providing an issue-free ride that won't have you hating your truck. At 2.3" of front leveling, this kit leaves just a smidge of front rake while still providing the clearance you need to squeeze on larger tires and get a much more leveled look that is sure to turn some heads. Each spacer features an offset design that provides extra spring clearance and makes getting an alignment much easier after your installation. The Stage 3 2.3" leveling kit installs right onto your F150's stock front coilover assemblies without any permanent modifications, making them an easy suspension upgrade for your 2021-2022 F150.Heavy-Duty Steel Construction with Black Powder Coat Finish and Nylock Nuts for Install
The F150 2.3" Offset Leveling Kit is built tough, allowing it to handle just about any application you have in mind for your aggressive F150 build. Each spacer is manufactured out of 1/4" thick steel that's expertly welded together for a perfect fit onto your 2021-2022 F150. The spacers come topped off with a black powder coat finish that helps keep them protected from corrosion in practically any climate or application. The spacers install right onto your F150's stock coilover assemblies without stud trimming and come with a full set of Nylock nuts that hold them fast during even the roughest driving. The 2.3" leveling kit comes with instructions and is proudly made in the USA.
Fitment: 2021-2022 F150
Alignment recommended: while these spacer's offset design helps with alignment, we still recommend getting a four-wheel alignment in order to correct front toe angle in order to avoid excessive or strange tire wear.
- Adds front leveling without the hassles of taller kits
- Provides 2.3" of front lift
- Improves tire clearance and reduces rake
- Offset design for more spring/UCA clearance and easier alignment
- Heavy-duty steel construction with powder coat finish
- Comes with Nylock nuts and instructions
- Made in the USA
