2021-2022 F150 AlphaRex LUXX Series Alpha-Black LED Projector Headlights 880169
Stage3Motorsports
Diamond Sponsor
Apr 27, 2021
310
730
473
2021 F150 STX CrewCab 4x4
Ford F-150 2021-2022 F150 AlphaRex LUXX Series Alpha-Black LED Projector Headlights 880169 {filename}
2021-2022 F150 AlphaRex Headlights Features:
  • Unique look and function with better output than stock
  • Pair of headlights with LED high and low beam
  • Features LED projectors with bright, white color temperature
  • Includes sequential LED turn signals and white running lights
  • Black housings with smoked LED outline strips
  • Installs right in place of the stock headlights
  • Require minor wiring for certain functions
  • Will not fit F150s with OEM LED headlights
Adds an Impressive Look, New Functionality, and Improved Lighting Output to your 2021 F150
Your 2021-2022 F150 may be tough and capable, but the base halogen headlights really let your truck down when it comes to both looks and lighting output. The AlphaRex Luxx Series Alpha Black LED Headlights feature an aggressive and stylish design and feature built-in LED projectors that produce far more lighting output than the stock halogen bulbs. The LUXX Series headlights also come standard with a sequential amber LED turn signals that give your 2021-2022 F150 a unique, modern look that is sure to turn some heads. Each headlight also features a startup sequence when unlocking your truck so that you can enjoy the LUXX Series headlights for all occasions. This particular version of the F150 LUXX Series Headlights feature an Alpha-Black styling theme with black housings and smoked LED outline and sequential strips so that you can ditch the bright looks of the base reflector halogen headlights. The AlphaRex LUXX series headlights are a nice upgrade over the factory headlights that are sure to turn some heads both on and off-road.
Features LED Projectors for Low and High Beams with Dual-Function LED Outline and Y-Strip in a Black Housing
Each set of AlphaRex LUXX Series headlights pairs potent LED projectors with unique features and styling to create a set of headlights that's both amazing to look at and generates improved forward lighting output over the factory headlights. The LUXX Series headlights are built around a pair of powerful LED boards for the high and low beams. Both LED boards are housed inside a highly-specialized projector assembly that produces a long-range beam with a distinct cutoff that keeps the headlights from blinding other drivers. Each LUXX headlight has a dual-function LED outline and a Y-shaped interior LED strips that feature a dual-function design with both a white running light and a sequential turn signal which gives your F150 a great look. The LED projectors have a bright, white coloration that looks much better than the yellow-ish glow of the factory halogen headlights. The LUXX series headlights have a clear lens and install right in place of the factory headlights with only minor amounts of wiring.
Fitment: 2021-2022 F150 with halogen headlights
For base halogen headlights only: these AlphaRex headlights will only fit F150s with base halogen headlights. They will not fit F150s with OEM LED projector headlights.
Minor wiring required: these headlights require minor wiring for their functions.
Bullett
Matt
Mar 10, 2021
160
136
Saratoga NY
2021 F150 STX, 2016 Accord Touring
Accountant
Do you have a coupon code for the other Luxx series black headlights?
Stage3Motorsports
Stage3Motorsports
Diamond Sponsor
Apr 27, 2021
310
730
473
Stage3Motorsports
Stage3Motorsports
Diamond Sponsor
Apr 27, 2021
310
730
473
Mateo_Hams
Matt
Apr 13, 2022
Missoula, MT
Ordered: 2022 F-150 XLT 301A 3.5L Ecoboost HDPP
Can you say more about the wiring requirements? What kind of extra work is necessary and what functions become available?
gooby
Jun 17, 2022
195
77
FL
2022 F150 XL
About to purchase but undecided on black or alpha black. Thoughts for a carbonized gray with black rims? Wish we had more pics on trucks.
Stage3Motorsports
Stage3Motorsports
Diamond Sponsor
Apr 27, 2021
310
730
473
The DRL feature on the lights requires 1 wire to be run from each light to the fuse box, more info can be see on the instructions linked below.
https://www.alpharexusa.com/Install...rd-F-150-AlphaRex-Headlights-Installation.pdf
I know Ill try to get some more pics from customers so we can update some of the listings, at the end of the day they will both be a great choice, I think the Alpha-black if you want a blacked out look, the black give a slight contrast looks with the while lens on the drl.
Ford F-150 2021-2022 F150 AlphaRex LUXX Series Alpha-Black LED Projector Headlights 880169 1656372464474
qxh04470
Greg
Jul 12, 2022
2021 Volvo S60 T5 Momentum
proofreader
About to purchase but undecided on black or alpha black. Hi! I can provoke you pros aces thesis composing help for the compelling obtaining of a made work out of any complexity - from a term paper help https://www.superiorpapers.com/term-paper-writing-service.php to a piece! Here, capable writers will make it for you on time, without duplicating. I for one go to them in circumstances where I need a real chance and energy to think about myself.
Thank you for question!
I chose alpha black - I think they look great!
somecatchyphrase
Sep 10, 2022
89
79
Orlando
2023 F150, 2023 Audi Etron Quattro
Doer of stuff and things.
Any word if these 2021-22 headlights will fit a 2023 F150 XL?
Graygoose2021
Nov 18, 2021
1,849
1,753
Central US!
Sales
Yes, should be same fit.
Here are the Alphas on a silver STX.
Ford F-150 2021-2022 F150 AlphaRex LUXX Series Alpha-Black LED Projector Headlights 880169 20220701_153753
Ford F-150 2021-2022 F150 AlphaRex LUXX Series Alpha-Black LED Projector Headlights 880169 20220706_180441
Ford F-150 2021-2022 F150 AlphaRex LUXX Series Alpha-Black LED Projector Headlights 880169 20220701_153950
adamscotth
Oct 13, 2022
proofreader
Ajzride
Alan
Jun 6, 2021
828
1,040
21Mach-E / 65Mustang / 21PB 502A 157"
C&A
I installed these today to replace my busted LED Projectors. Using the conversion harness it is plug and play, you do not need the DRL harness from the fusebox to the lights (LED Projector equipped trucks). This was not clear at all from the instructions and cost me about an hour of time.
