Have a few of these available to ship, message me for pricing!
2021-2022 F150 ADD Honeybadger Front Off-Road Bumper F190111040103
Highlights:
The 2021-2022 F150s may be some of the most good-looking and capable trucks on the road, but even they could use some help when it comes to being at their best off-road. Our cross-town neighbors over at ADD know this better than anyone, which is why they developed a totally redesigned version of their awesome Honey Badger Bumper for 2021-2022 F150s. The 2021-2022 F150 version of the ADD Honeybadger features a hyper-aggressive look with many of the design elements of the older Honeybadger front bumpers, but sits much higher and tighter with your F150's body than older versions, which gives your F150 a sleek, tough look that is sure to turn some heads. The Honeybadger front bumper doesn't just look great, it also gives your truck a lot of extra front-end protection thanks to its heavy-duty plate steel construction. Each Honeybadger bumper also provides an improved approach angle and more wheel well clearance so that you can squeeze on bigger tires and get improved off-road capability. Four Mounts for Powerful Off-Road LED Lighting
The Honeybadger front off-road bumper comes loaded down with light mounts and features so that you can get the powerful off-road lighting you need for late-night trail runs. Each Honeybadger front bumper has the ability to mount up a 30" radius LED light bar on its upper lip, which gives your truck tremendous amounts of off-road lighting power. Supplementing the 30" radius bar, a 20" LED bar mount sits behind the main skid plate and shines through ADD's Honeybadger laser-cut lettering and logo for a great look. Behind each of the side panels, ADD includes mounts for a single 3" LED light with a slight cant to each side to give your truck some nice ditch or work lighting. Combined, the Honeybadger bumper features four total built-in light mounts that gives your truck awesome levels of off-road lighting capability without having to slice up or drill into your truck. Extremely Strong Plate Steel Construction with Tight, Low-Profile Design and Powder Coat Finish
Each Honeybadger front bumper is built extremely tough and was carefully designed to give your F150 a tight fit in a durable package. The Honeybadger is made entirely of plate steel like a boxed steel bumper, but has a low-profile, body-hugging design that even keeps the stock tow hook locations. The bumper features a front skid plate and upper edge that provide a clean, near-seamless look for your F150. The bumper features a two-tone powder coat finish with a black Hammertone finish on the bumper's main body and a satin black finish on the skid and side plates that looks great on practically any F150 paint color or styling theme. The Honeybadger features a bolt-on installation and comes with front sensor provisions. An optional Adaptive Cruise Control relocation bracket can even preserve your truck's OEM Adaptive Cruise Control System with the bumper installed. ADD proudly builds each of these bumpers right here in the USA.
Fitment: 2021-2022 F150
Does not include lights: The bumper does not come with light bars. All accessories must be purchased separately.
Adaptive Cruise Control: if your F150 is equipped with Ford's optional Adaptive Cruise Control System, the installation of the bumper will render the Adaptive Cruise Control System inoperable unless used in conjunction with ADD's optional Adaptive Cruise Control Relocation Bracket, which is available from our drop-down menu above.
Highlights:
- Vicious looks and improved off-road capability
- Durable plate-steel construction
- Features four mounts for off-road LED lights
- Low-profile design with more clearance
- Two-toned powder coat finish
- Bolt-on replacement for stock front bumper
- Made in the USA
