2021-2022 F150 6.5ft Bed BAK Revolver X4s Roll-Up Tonneau Cover 80337
Highlights:
While roll-up tonneau covers are convenient for bed access and lightweight, they aren't the most secure or durable things in the world. The BAK Revolver X4s bridges the gap between traditional roll-up tonneaus and hard-folding by maximizing your bed access and keeping your rear view clear like a roll-up tonneau, while adding the security of a folding tonneau cover thanks to its unique slatted aluminum design. The Revolver X4s is a great tonneau cover solution for practically any truck and has a low-profile mounting that give your 2021-2022 F150 a sleek, clean look. Each Revolver X4s drops right into your F150 without any permanent modifications thanks to its clamp-in rails that makes it easy to get the tonneau up and running on your 2021-2022 F150 build.
Features Aluminum Slatted Substructure with Vinyl Top Layer
The Revolver X4s for 2021-2022 F150s combines a strong, durable construction with the convenience of a rolling tonneau design so that you get a high-quality, yet easy-to-use tonneau cover system. The Revolver X4s utilizes rows of aluminum cross-bars that are bonded to a vinyl tonneau cover with enough room between them to allow for the tonneau cover to roll all the way against your truck's cab without blocking the rear window. The slatted structure keeps the vinyl upper layer taut and prevents anyone from cutting through the tonneau and walking away with any bed-stowed gear or accessories. The tonneau cover installs and rolls along a pair of clamp-in rails that require no drilling or other permanent modifications to your F150. The vinyl layer features a sleek matte black finish that looks great on practically any F150 paint color or styling theme. Each tonneau cover comes with all necessary installation instructions and hardware. The X4s comes backed by a 5-year limited warranty.
Fitment: 2021-2022 F150 6.5ft Bed.
For 6.5ft Beds Only: this tonneau cover will only fit F150s with a 6.5ft bed. Versions for 5.5ft beds and 8ft beds are also available.
Highlights:
- Adds roll-up convenience with folding security
- Strong aluminum construction with rolling design
- Bonded aluminum slats with vinyl upper layer
- Stylish matte black finish
- Easy, drop-in installation
- Comes with hardware and instructions
- Backed by a 5-year warranty
