These are back in stock for anyone in the market!
Pm me for forum pricing!
2021-2022 F150 4WD ICON Stage 1 0-2.75" Suspension Package K93111
2021-2022 F150 ICON Stage 1 Kit Features:
F150s that are heading out onto the trail are going to find out pretty quickly that their stock suspension parts just can't handle the strain, so if you're looking to push your 2021-2022 F150 hard off-road, you should get everything you need for your next adventure all in once place. The ICON Stage 1 Suspension Package for 2021-2022 F150s gives your truck a nice suspension overhaul that will allow you to handle tough trails and off-road applications without breaking a sweat. The ICON Stage 1 Suspension Kit comes standard with a pair of ICON 2.5 VS IR front coilovers and ICON 2.0 Rear Shocks that work together to give your 2021-2022 F150 a nice improvement in on-road handling while greatly enhancing off-road performance so that you can hit those trails without shaking your aggressive 2021-2022 build apart. The front coilovers even provide up to 2.75" of front ride height which reduces your F150's rake and allows you to fit on larger wheel and tire combinations to get you the ground clearance and traction you need to handle tough terrain.
Pair of Coilovers with 2.5" Diameter Shock Bodies with 600lb-in Spring and Digressive Valving
The ICON 2.5 Coilovers feature high-quality components and features that combine to give your 2021-2022 F150 excellent levels of performance and handling, both on and off-road. Each coilover is built around a 2.5" diameter aluminum shock body that features a larger fluid volume than stock that provides both improved damping and heat resistance than the stock coilover assemblies. The aluminum body also provides improved heat dissipation over standard steel-bodied shocks so that you get less fade during hard off-roading. Each 2.5 coilover is wrapped with a 600lb-in coil spring that provides a good balance of energy absorption and ride quality both on pavement and out on the trail. The ICON 2.5 coilovers feature a 7/8" shaft with finely-tuned digressive valving that can handle extremely aggressive off-road applications without letting you or your 2021-2022 F150 down. The coilovers come standard with CNC machined billet aluminum mounts with black anodized finishes that look great and keep the coilovers attached to your truck no matter how hard you're ripping it around. Each set of coilovers come with install hardware and instructions, giving you everything you need for a bolt-on install.
2.0 Rear Shocks with Monotube Aluminum-Body Shock Absorber
ICON builds each shock with a nitrogen-charged monotube design that makes it extremely responsive and reliable. The piston features a one-piece linear/digressive design that provides excellent performance on street and off-road. Each shock comes standard with 5/8" polished nitro-steel shafts and 6061 aluminum rod ends to help improve durability and reliability even further. The 2.0 Aluminum shock comes with polyurethane bushings to minimize deflection and improve longevity over your stock rubber bushing. Each shock easily installs right in place of your stock shock, making it one of the most hassle-free suspension upgrades you can find.
Fitment: 2021-2022 F150 4WD
For 4WD F150s Only: this kit is specifically designed for 4WD F150s. A version for RWD/2WD F150s is here.
Will not fit F150s with CCD: this kit will not fit or function on F150s with Ford's optional Continuous Control Damping (CCD) system. Please verify whether or not your F150 is equipped with CCD before ordering.
- Excellent suspension upgrade for both front and rear
- Improves on-road handling and adds off-road performance
- Includes ICON 2.5 coilovers and ICON 2.0 rear shocks
- Adds up to 2.75" of front ride height
- Improves damping and reduces fade over stock
- Drop-in replacements for stock
- Will not fit F150s with CCD Systems
