Join Noah for the latest of our Installation videos.
Beautiful! great looking truckFox 2.0 suspension. Cranked spring collar tighter another .5" and added a Autospring 3" rear block. Where you take out the factory 1.5" block and replace it with the 3" to gain 1.5" over the factory height.
Yea its just loose like that, you can always trim it with scissors if you don't like it. Thats the driver side, there is a plug right there held in with that plastic retainer right above your red arrow so just be careful you dont snip any wire or anythingJust had mine installed today. Does anyone know how the shielding/felt on top of the coilover is supposed to look like?
Mine seems to be sitting loose on top for both driver and passenger side. This was installed at the Ford Dealer.
Can you share what trim your truck is and how much lift it gave you? Seems like people are getting less than advertised lift.Just had mine installed today. Does anyone know how the shielding/felt on top of the coilover is supposed to look like?
Strange. Just seems odd like it should be attached. I dont see any plugs from the top view.Yea its just loose like that, you can always trim it with scissors if you don't like it. Thats the driver side, there is a plug right there held in with that plastic retainer right above your red arrow so just be careful you dont snip any wire or anything
Platinum 3.5 EcoBoostCan you share what trim your truck is and how much lift it gave you? Seems like people are getting less than advertised lift.
Factory block is only 1.25 so you picked up a hair more.Fox 2.0 suspension. Cranked spring collar tighter another .5" and added a Autospring 3" rear block. Where you take out the factory 1.5" block and replace it with the 3" to gain 1.5" over the factory height.
I'm meaning don't get carried away if you decide to trim it, could easily cut through that wire if you're using scissorsI dont see any plugs from the top view.
Gabe,Fox 2.0 suspension. Cranked spring collar tighter another .5" and added a Autospring 3" rear block. Where you take out the factory 1.5" block and replace it with the 3" to gain 1.5" over the factory height.
