2015-2022 F150 SuperCrew Husky Liner Underseat Gear Box 09281
Highlights:
Husky Liner's lineup of F150 gear boxes have always been one of the most handy things that you can put in your truck, especially if you're hauling a ton of gear or use your F150 out on the job site. This easy-to-install gear box fits right under the rear bench seat of your F150 and attaches securely to your seat frames using adjustable straps. The Husky Liner F150 Gear Box is perfect for stowing tie-downs, straps, tools, and whatever else you may need at a moment's notice. The gear box can help turn your truck into a mobile garage or work bench for just about any application. The benefits of the Husky Gear Box allow you to keep all of your important gear out of sight until you need it while keeping the interior of your F150 tidy, clean and organized.
Excellent Fit and Compact Design
The gear box is extremely easy to install and fits under your rear bench with just enough clearance to easily lift your seats to gain access. The Husky Liner Gear Box includes removable foam dividers that allow you to tailor the box to your specific needs or application, for safe and neat storage of anything from tools and jumper cables to emergency gear, electronics or anything else you need to safely store out of sight. The gear box tucks in perfectly under seats and won't affect rear leg room whatsoever.
Fitment: 2015-2022 Ford F150 - SuperCrew/Crew Cab only.
Fitment Note: this version of the Husky Gear Box will only fit 2015-2022 F150s with a SuperCrew/Crew Cab and will not fit F150s with a SuperCab/Extended Cab.
A version for SuperCab F150s is available here.
Highlights:
- Provides increase in under-seat storage capacity
- Spans entire rear bench
- Holds a ton of gear, tools, or cargo
- Durable Construction
- Includes foam inserts
- Extremely easy installation
