On Sale and in stock and ready to ship!
2015-2021 F150 & Raptor SuperCrew Go Rhino Dominator DSS Step Sliders DSS4155T
Highlights:
While just about any side steps can help your F150 or Raptor, few give your truck the aggressive looks and side protection as the Go Rhino DSS Step Sliders. While not true frame-mounted rock sliders, the Dominator DSS Sliders feature an aggressive, off-road inspired look and will add some extra protection for your F150 or Raptor's love handles and rocker panels. The DSS Step Sliders feature an extremely durable and strong construction that can withstand bumps and bruises during your daily grind or from light trail use. The DSS Step Sliders feature a fairly wide step area that runs the entire length of the steps so that you get easy access to your truck's cab and roof. The Dominator DSS Step Sliders drop right onto your F150 or Raptor without the need to drill, trim, or make any permanent modifications to your F150. Low-Profile Design with Tubular Steel Construction and Powder Coat Finish
The F150 and Raptor Dominator DSS Step Sliders were designed to be extremely strong and low-profile enough to not get hung up on obstacles out in the bush. The DSS Sliders feature a tubular steel construction with a dimpled steel step area in a one-piece design. The steps come standard with a textured black powder coat finish that gives the steps a great look and excellent resistance against corrosion in practically any climate or application. The DSS Sliders tuck close to your F150 or Raptor's body while still providing enough of a step area to give you firm footing. The DSS Sliders come with brackets and hardware that allow you to drop the steps right onto your truck using the mounts for the OEM steps, making them a hassle-free upgrade for your truck.
Fitment: 2015-2021 F150 SuperCrew
For SuperCrew Only: these steps will only fit F150s and Raptors with SuperCrew/Crew Cabs and will not fit SuperCab/Extended Cab or Regular Cab/Standard Cab models.
Highlights:
- Provides extra protection and an off-road look
- Pair of low-profile steps
- Full-length step area for better accessibility
- Strong tubular steel construction
- Textured black powder coat finish
- Easy, drop-in installation
- For SuperCrew Cabs only
- Not true frame mount rock sliders
