2015-2021 F150 & Raptor 17x8.5" Ford Performance Beadlock Wheel +34mm Offset M-1007-DC1785A
Stage3Motorsports
Diamond Sponsor
Apr 27, 2021
310
730
473
2021 F150 STX CrewCab 4x4
2 sets in stock and available for immediate shipping for anyone who is looking to upgrade with the Ford Performance Raptor Beadlock wheel.
Ford F-150 2015-2021 F150 & Raptor 17x8.5" Ford Performance Beadlock Wheel +34mm Offset M-1007-DC1785A 1633037198381
Highlights:
  • Provides improved bead holding in slick package
  • Includes OE-style wheel with beadlock ring
  • Strong forged aluminum wheel
  • Cast aluminum beadlock ring with fasteners
  • Gray Metallic wheel with natural beadlock ring
  • 34mm offset with 6.2" backspace
  • Beadlock is for off-road use only
  • Single wheel only
Keeps your F150 or Raptor's Bead Off-Road in Clean, OE-Style Package
Keeping your tire's bead when you're ripping your F150 or Raptor around off-road is absolutely key if you don't want your day getting ruined before it's barely even begun. If you want to keep your F150 or Raptor's bead off-road while keeping a clean look on-road, then Ford Performance has your answer with their very own 17x8.5" beadlock wheel. This wheel was specifically designed for 2019-2020 Ford Raptors and feature a slick OE-style look with the ability to lock your tire's bead off-road, which can save your bacon if you're ripping around at low tire pressures. Each wheel features a two-piece design of the wheel and separate beadlock ring, which feasibly allows you to stay street-legal by not running a beadlock when you're on the street. The wheels feature a durable construction and feature a near-stock 34mm offset and 6.2" backspace that keeps the wheels and tires fairly tucked for an OE-style stance. Forged Aluminum Construction with Aluminum Beadlock and Ford Center Cap
The Ford Performance Beadlock Wheel features an extremely strong construction that allows it to handle the toughest applications both on and off-road. The Ford Performance Beadlock wheel is made out of forged aluminum that's incredibly durable and is topped off with a Magnetic Gray paint that's then clear-coated to OEM specifications to preserve the color. The wheel includes a center cap with "FORD" lettering that further adds to the stock-style look of the wheel. Each wheel comes standard with an aluminum beadlock ring with a natural aluminum finish that gives the wheel an awesome two-tone look. The beadlock ring comes with all of its required fasteners and installation instructions. The beadlock ring is meant for off-road use only and may not be legal for street use in your area.
Wheel Specs:
  • Size: 17x8.5"
  • Offset: 34mm
  • Backspacing: 6.2"
Fits The Following Models:
  • 2004-2021 Ford F150
  • 2010-2020 Ford Raptor
Beadlock for off-road use only: the beadlock ring included with this wheel is for off-road use only and may not be legal for street use in your area.
