Plenty of these in stock and ready to ship and I can pair them with a BDS 4 or 6" lift kit to make your own coilover lift kit without the wait.
Shoot me a pm for pricing or package info.
2014-2020 F150 4WD Fox 2.5 Remote Reservoir Front Coilover Kit for 4-6" Lift Kits 883-02-114
Highlights:
Your average 4" to 6" lift kit for the 2014-2020 F150s comes with strut spacers to provide your truck with the right amount of front lift, and while they get the job done, they don't do anything to actually improve your F150's ride or off-road performance. That's where the Fox 2.5 Remote Reservoir Front Coilover Kit for 4-6" Lift Kits comes in. This powerful coilover kit comes with a pair of high-quality and high-performance Fox 2.5 Coilovers that are long enough to work as a standalone coilover with a 4-6" suspension lift kit. These coilovers allow you to ditch your truck's strut spacer and factory coilover assembly to get a huge bump in on-road handling and off-road performance in practically no time. The Fox 2.5s eliminate body roll and jounce on the street and are capable of soaking up absolutely brutal levels of punishment off-road, allowing you to push your 2014-2020 F150 to the absolute edge of its performance envelope and tackle some of the toughest terrain on the planet. 2.5" Diameter Shock Body with Eibach Coilover Spring and Aluminum Remote Reservoir
The Fox 2.5 Remote Reservoir Coilovers for 4-6" lifted F150s feature a high-quality construction and offer up a perfect fit for your aggressive truck. Each coilover is built around a large 2.5" diameter shock body that has a larger oil capacity than your factory shock assemblies and are each performance valved to deliver excellent rebound and compression in practically any application, climate, or terrain. The shock bodies are made of aluminum with a zinc-plated and double clear-coated finish for corrosion-free operation. The coilovers feature 7/8" hard chromed steel shafts and a 6061-T6 aluminum and hard-anodized piston that work together to handle extreme applications without letting you down. Each coilover is wrapped in an application specific Eibach 3.0 coilover spring that's mounted to an upper adjustment collar that allows you to change the coilover's ride height to match your F150's lift. The coilovers feature billet aluminum mounts with a black anodized finish. The coilovers are paired with remote-mounted aluminum reservoirs that further increase oil capacity and improve cooling to mitigate fade in even the most intense off-road applications.
Fitment: 2014-2020 F150 4WD with a 4-6" Lift Kit
For lifted F150s only: this coilover kit will only fit F150s with either a true crossmember 4-6" suspension lift kit. It will not fit leveled F150s or F150s with a body lift.
Preset Ride Height Note: these coilovers come out of the box preset for 6" lift kits and will need to be adjusted down for F150s equipped with 4" suspension lift kits.
Highlights:
- Huge improvement in handling and off-road performance
- Built specifically for 4-6" lifted F150s
- 2.5" diameter shock bodies with Eibach spring
- Remote-mounted reservoir for fade resistance
- Adjustable ride height to accommodate 4-6" lifts
- Replaces strut spacers and stock coilover assemblies
