Looks like these have finally come in from Ford Performance and started shipping!
2004-2022 F150 Ford Performance 22x9.5" Gloss Black Wheels with Ford Performance Lettering with TPMS Sensors M-1007K-S2295GB
F150 Ford Performance Gloss Black Wheel Features:
A new wheel is a great way to change up your 2004-2022 F150's exterior appearance, but if you don't want to ruin your truck's slick factory looks, then there's no one better to turn to than Ford Performance itself. The Ford Performance 22x9.5" Gloss Black Wheel Kit for 2004-2022 F150s is a clean way to add a subtle change in appearance to nearly any F150 build. The OEM Gloss Black wheels are a redesign of the base OEM wheels with a stylized 6-spoke design that is sure to turn some heads. The wheel comes standard with a gloss black finish and features "Ford Performance" lettering in the center of one of the spokes. This complete set of four wheels also come with four OEM TPMS sensors and an activation tool.High-Strength Cast Aluminum Construction with Gloss Black Paint and Clear Coat Finish
The Ford 22x9.5" gloss black wheels are made out of durable materials and was carefully designed for a perfect fit onto your F150 build. The wheels are made entirely out of cast aluminum alloy that can handle just about any application or climate without letting you or your F150 down. The wheels are carefully machined and features an OEM 6x135mm bolt pattern and an 87.1mm hub bore that gives the wheel a perfect, hubcentric fitment onto your F150. The wheels come standard with a +44mm offset with 7" of backspace that keeps the wheel tucked inside your F150's wheel wells for a stock-style stance. Each wheel comes topped off with a gloss black paint with a stock-style clear coat for extra protection. Ford Performance includes a full set of four Ford OEM TPMS sensors and an activation tool that makes it much easier to get these wheels mounted and on your truck.
Fitment: 2004-2022 F150
Wheel Specs:
- Excellent styling with tough, aggressive look
- Original equipment for 15-20 Lariat FX4
- Set of four 22x9.5" wheel with +44mm offset
- 7" of backspace for OE-style tucked looked
- Cast aluminum construction
- Painted gloss black with Ford Performance lettering
- Comes with TPMS Sensors and activation tool
Wheel Specs:
- Size: 22x9.5"
- Bolt Pattern: 6x135mm
- Hub Bore: 87.1mm
- Offset: +44mm
- Backspacing: 7"
