UGADawg96
I mean who doesn't like to come straight here with coffee first thing in the morning. And there is nothing wrong with a little truck picture porn. lol.
This week!! I can feel it Santa won't let us downMeanwhile, back at the fort...
I am leaning towards the same setup for our kayaks, but I need to run across the scales with our TT after the LINE-X gets put in to make sure we have payload for it all. That setup is sweetTruck got an “Overhaul” this weekend. Installed a Retrax XR pro and a Yakima Overhaul rack.
Looks great! Does the tailgate shut easily while cover is closed?Truck got an “Overhaul” this weekend. Installed a Retrax XR pro and a Yakima Overhaul rack.
First truck, first tonneau... so you're not getting expert advice here. I found the The Retrax install to be fairly easy. The bed rails come with a shim that allows you to set the tracks exactly 1/8" off the tailgate. The weatherstrip also forms a good seal along the top. This results in a solid seal and no issues at all manually opening/closing the tailgate and no issues using the power function on the tailgate. You can open/close the tailgate with the cover fully extended, locked in place. No problem.Looks great! Does the tailgate shut easily while cover is closed?
That is one serious rack!! Looks great! I need to figure a set up for mine as well. I had Yakima rack on the CanyonTruck got an “Overhaul” this weekend. Installed a Retrax XR pro and a Yakima Overhaul rack.
Just picked up a can at Home Depot today. Need to find a minute to knock out this exercise.I had the same issue after less than 1 month of truck being built. I crawled under, brushed off the diff, and applied a coating to help reduce ongoing rust. I’ll attach a picture. Got it from Home Depot. Testing shows it lasts longer and works better than fluid film, with a similar active ingredient.
User Name | Dest | Plant | Seq # | Blend Date | Built | Shipped | Del ETA | Delivered | PU |
Fordtheriver | LA | DRB | 1921 | 20211101 | 11/2/2021 | 11/6/2021 | 23-Nov | 12/16/2021 | X |
Cdubs * | PA | DRB | 2026 | 20211101 | 11/2/2021 | NA | 26-Nov | 11/18/2021 | X |
WRS | OK | DRB | 2788 | 20211101 | 11/2/2021 | 11/3/2021 | 26-Nov | 11/18/2021 | X |
SPARKY150 * | CA | DRB | 2826 | 20211101 | 11/2/2021 | 11/6/2021 | 5-Dec | 11/19/2021 | X |
4jeff | OH | DRB | 5370 | 20211101 | 11/4/2021 | NA | 22-Nov | 11/20/2021 | X |
riverdave | MA | KC | 6436 | 20211101 | 11/2/2021 | 11/4/2021 | 7-Dec | 12/13/2021 | X |
Kilo5 | TX | DRB | 3657 | 20211102 | 11/3/2021 | 11/4/2021 | 26-Nov | 12/2/2021 | X |
gagniertom * | CT | DRB | 3920 | 20211102 | 11/4/2021 | 11/5/2021 | 22-Nov | 11/19/2021 | X |
MacTexas744 | TX | DRB | 4039 | 20211102 | 11/4/2021 | 11/7/2021 | 27-Nov | 11/15/2021 | X |
Eyeman60 * | NE | KC | 7263 | 20211102 | 11/3/2021 | 11/16/2021 | 21-Nov | 11/16/2021 | X |
jraab10 | CT | KC | 80 | 20211103 | 11/4/2021 | 11/12/2021 | 17-Nov | 11/12/2021 | X |
CarbonizedRCS | MO | KC | 437 | 20211103 | 11/4/2021 | 11/4/2021 | 15-Nov | 11/5/2021 | X |
dbagdbag | CO | KC | 533 | 20211103 | 11/4/2021 | 11/5/2021 | 27-Nov | 11/24/2021 | X |
Spleen_Merchant * | MI | DRB | 4409 | 20211103 | 11/4/2021 | 11/4/2021 | 14-Nov | 11/5/2021 | X |
Strengthrehab | TX | DRB | 4488 | 20211103 | 11/4/2021 | 11/6/2021 | 26-Nov | 12/2/2021 | X |
DBJohnston010 | GA | DRB | 4627 | 20211103 | 11/4/2021 | 11/5/2021 | 29-Nov | 11/18/2021 | X |
pkinneb * | PA | DRB | 4985 | 20211103 | 11/4/2021 | 11/10/2021 | 27-Nov | 11/22/2021 | X |
jac1990 | GA | DRB | 5009 | 20211103 | 11/3/2021 | 11/4/2021 | 1-Dec | 12/4/2021 | X |
CindyC-IL * | WI | DRB | 5046 | 20211103 | 11/4/2021 | 11/5/2021 | 20-Nov | 11/9/2021 | X |
allJUMPstyle | PA | DRB | 5185 | 20211103 | 11/4/2021 | 11/5/2021 | 27-Nov | 11/19/2021 | X |
AgieF150 | PA | DRB | 5308 | 20211103 | 11/4/2021 | 11/5/2021 | 28-Nov | 11/19/2021 | X |
VbPb | CA | DRB | 5456 | 20211103 | 11/4/2021 | NP | 9-Dec | 11/20/2021 | X |
SpazzStr0s | TX | DRB | 5464 | 20211103 | 11/5/2021 | 11/5/2021 | 4-Dec | 11/22/2021 | X |
ryan79260 | TX | DRB | 5598 | 20211103 | 11/4/2021 | 11/5/2021 | 2-Dec | 11/15/2021 | X |
tkbolts21 | NJ | KC | 1588 | 20211104 | 11/5/2021 | NA | 10-Dec | 11/26/2021 | X |
craig1wilsom1 * | CAN | DRB | 5813 | 20211104 | 11/10/2021 | 11/10/2021 | 22-Nov | 11/29/2021 | X |
Poorspecimen | CA | DRB | 6040 | 20211104 | 11/5/2021 | 11/6/2021 | 1-Dec | 11/23/2021 | X |
Plattypuss | PA | DRB | 6350 | 20211104 | 11/5/2021 | 11/6/2021 | 29-Nov | 11/19/2021 | X |
DetroitFD | MI | DRB | NP | 20211104 | 11/8/2021 | NP | NP | 11/12/2021 | X |
Chuck8588 | PA | DRB | 837 | 20211105 | 11/7/2021 | 11/9/2021 | 1-Dec | 11/22/2021 | X |
Portcallahan | WA | DRB | 868 | 20211105 | 11/7/2021 | 11/8/2021 | 2-Dec | 11/29/2021 | X |
UGADawg96 * | PA | DRB | 877 | 20211105 | 11/7/2021 | 11/14/2021 | 5-Dec | 11/26/2021 | X |
Dgretka * | MI | DRB | 1214 | 20211105 | 11/8/2021 | 11/12/2021 | 22-Nov | 11/15/2021 | X |
Bphil * | IL | DRB | 1290 | 20211105 | 11/14/2021 | NA | 30-Nov | 11/19/2021 | X |
DBL R | WA | DRB | 1307 | 20211105 | 11/7/2021 | 11/8/2021 | 8-Dec | 11/29/2021 | X |
Bee5ting | UT | DRB | 1501 | 20211106 | 11/5/2021 | 11/8/2021 | 8-Dec | 11/27/2021 | X |
BigBluegen14 | CAN | DRB | 1600 | 20211106 | 11/8/2021 | 11/9/2021 | 19-Nov | 11/16/2021 | X |
F150DAT | CO | DRB | 1791 | 20211106 | 11/8/2021 | NA | 28-Nov | 11/26/2021 | X |
PeanutGallery | AL | KC | 4187 | 20211107 | 11/8/2021 | NA | 25-Nov | 11/16/2021 | X |
* Spray in Bedliner etc |
