Calson
- Jul 16, 2022
- 12
- 706
- 340
- Monterey CA
- 2022 F-150
There was a television programin the 1980's, The Fall Guy, where they showed pickup trucks making incredible jumps. What the public did not realize was that after each jump they needed to replace the truck. The stunt people finally built a custom pickup with the engine behind the cab to reduce the weight over the front wheels and enabled it to last for multiple jumps and takes.
Flexing of metal leads to fatigue and in turn to failure. A fully boxed frame flexes a great deal less and is going to last a lot longer.
For light and medium duty pickup trucks the payload is calculated at the factory based on how the truck is equipped and its seating capacity. Each passenger seat is credited with adding 150 lbs to the load of the truck. There is also the limiting factor which is often the wheels and tires and not the rear axle or rear suspension.
My stock GM 2500 had a payload capacity from the factory of 2800 lbs but the AAM rear axle was rated at 11,000 lbs so the limitation was with the leaf springs and the tires. I swapped out the factory tires rated at 2700 lbs for Nitto ones rated at 3750 lbs and I added a double leaf set of SuperSprings. Next was controlled dampening which I accomplished with Rancho adjustable XL shocks at all four wheels. With a 3700 lb slide-in camper load the truck was level and it handled acceptably in tight turns were more than 50% of the load was being supported by the outside wheel.
