Nasto
Wow, that looks tight! ??Picked mine up at the dealer yesterday after work and with about 8” to spare it even fits in the garage. Will probably add my Bedrug and Bak X4s tomorrow.
User Name | Destination | Plant | Trim | Ordered | Build Date | Delivery ETA | Shipped | Delivered | Picked Up | Pictures Posted |
Grizzlee* | TX | DRB | King Ranch | 10/09 | 01/06 | 01/31 | 01/10 | 01/19 | 01/21 | |
kb2755 | ON, CA | DRB | XLT | 10/01 | 01/03 | 01/10 | 01/08 | 01/17 | | |
Satellite67* | TX | DRB | King Ranch | 10/28 | 01/05 | 02/06 | 01/15 | 01/19 | | |
_____________ | ________ | ___ | ______ | _____ | ___ | _____ | _____ | ______ | ____ | _____ |
smyph* | IA | DRB | Lariat | 10/14 | 01/03 | 01/30 | 01/10 | |||
Buhorn | IA | DRB | Lariat | 10/20 | 01/06 | 01/31 | 01/10 | |||
Nasto* | ID | DRB | Lariat | 10/28 | 01/05 | 01/28 | 01/11 | |||
mtnbike009* | CO | DRB | XLT | 11/09 | 01/04 | 02/13 | 01/13 | |||
thomhunt | IA | DRB | Lariat | 11/29 | 01/06 | 02/01 | 01/13 | |||
Yawyeet | AL | DRB | Lariat | 11/03 | 01/03 | 02/05 | 01/15 | |||
Bud | VA | DRB | Lariat | 11/15 | 01/05 | 01/25 | ||||
thudnblunder* | IA | DRB | Platinum | 11/16 | 01/08 | 02/08 | ||||
*Spray-in bed liner, wheel well liner, other add-on accessories |
Turns out, it’s easier to back it in than drive it in. I’ve a side entrance garage which makes it a bit more fun….Wow, that looks tight! ??
Backing in is the only way to go!Turns out, it’s easier to back it in than drive it in. I’ve a side entrance garage which makes it a bit more fun….
Didn’t get the Bak X4s on today… The tailgate seal from ESI was simple and quick (use updated online instructions as those in the package are dated). Bedrug is in but took a while taking all the BoxLink, Tie downs, and PowerPro out, cutting holes for screws and putting all back.Picked mine up at the dealer yesterday after work and with about 8” to spare it even fits in the garage. Will probably add my Bedrug and Bak X4s tomorrow.
Happy with the fit for the Bedrug? Even though it was a bit of pain to cut out, was it worthwhile? Debating between this and Line-X. Thx.Didn’t get the Bak X4s on today… The tailgate seal from ESI was simple and quick (use updated online instructions as those in the package are dated). Bedrug is in but took a while taking all the BoxLink, Tie downs, and PowerPro out, cutting holes for screws and putting all back.
We're in the same boat, or rail car, or whatever! Union Pacific railed it to Salk Lake City last week. Supposed to be on a carrier to Idaho and delivered to dealer this week. Good luck! ?Ford tracker is saying truck shipped, eta is this week. palsapp shows a freight bill number, but the status is pending. Dealer previously said trucks go by train to Kanas City, then get delivered to the dealer. Guessing my truck is sitting waiting for a ride to Iowa.
Yes, very happy so far. Love the fact it’s easy on the knees, wood and furniture, and my dog. There are a few fit issues with the uprights in the bed and did not use the stamped cutouts on the back of the Bedrug. Removed all BoxLink and tie downs, then put the screws barely back in. Once at that area I used a razor blade to cut on top of screw poke it through, then take it out and mount tiedown and BoxLink on the surface. Does not work for PowerPro because did not want try and figure out if could remove cable. Same with lights, just feel and cut. Did leave enough around PowerPro to tuck edges under the PowerPro - except on left where I missed my cut. (Be careful removing PowerPro as there are pins on the bottom and left edge)Happy with the fit for the Bedrug? Even though it was a bit of pain to cut out, was it worthwhile? Debating between this and Line-X. Thx.
Congrats!!Picked mine up at the dealer yesterday after work and with about 8” to spare it even fits in the garage. Will probably add my Bedrug and Bak X4s tomorrow.
I found this video pretty well done also - he used the same method as you did for the Boxlink and tie-downs.Yes, very happy so far. Love the fact it’s easy on the knees, wood and furniture, and my dog. There are a few fit issues with the uprights in the bed and did not use the stamped cutouts on the back of the Bedrug. Removed all BoxLink and tie downs, then put the screws barely back in. Once at that area I used a razor blade to cut on top of screw poke it through, then take it out and mount tiedown and BoxLink on the surface. Does not work for PowerPro because did not want try and figure out if could remove cable. Same with lights, just feel and cut. Did leave enough around PowerPro to tuck edges under the PowerPro - except on left where I missed my cut. (Be careful removing PowerPro as there are pins on the bottom and left edge)
Went this route as I can always go LineX later and the cushioning is great. Bedrug also dampens noise levels.
Just my .02 and probably worth less than that.
Granger says my truck was built on 1/8 and to expect delivery 2-8 Feb but Ford tracker still shows it under production.Ford tracker is saying truck shipped, eta is this week. palsapp shows a freight bill number, but the status is pending. Dealer previously said trucks go by train to Kanas City, then get delivered to the dealer. Guessing my truck is sitting waiting for a ride to Iowa.
He shoots....he scores! Congrats!She’s home! Dark now, I can provide more pictures later
